Hi there,
You will have to try and trigger the lock from down past the glass with a length of bent stiff wire, you will have to remove the trim on the other door to work out lengths and position to hit the lock, failing this, you can remove the seat and try and get the trim off, but getting the seat out will also be a hand full.
Mark (mhpautos)
SPONSORED LINKS
Monday, May 17th, 2010 AT 1:10 AM
