Mike.
Be very carefull working with the ECM even static electricity can damage the ECM .. the ECM will shut the car down if it senses something is wrong .. there are no cicuit breakers to cut engine .. unless you want to call the ECM a cicuit breaker .. ?
1))The ECT sensor would give driveability issues once vehicle is running !!
Engine Coolant Temperature (ECT) Sensor
The ECT contains a built-in thermistor in which resistance varies according to engine coolant temperature. The ECT delivers an input signal to THW terminal of Engine Control Module (ECM). The ECM uses input signal for controlling Pulsed Secondary Air Injection (PAIR) system (if equipped), fuel injection system, overdrive operation on electronically controlled transaxles/transmissions, ignition timing (spark advance), idle speed control system, fuel pressure control system (if equipped), heated oxygen sensor system (if equipped) and EGR system.
2))The IAT will give hard start and cutting out/stalling isssues to the vehcile on starting!!
Intake Air Temperature (IAT) Sensor
Intake air temperature sensor is mounted in either airflow meter or air filter housing. Intake air temperature sensor measures incoming intake air temperature and delivers an input signal to THA terminal of Engine Control Module (ECM) for controlling fuel injection system, fuel pressure control (if equipped) and heated oxygen sensor systems (if equipped).
3))The MAP sensor will give stalling/cutting out issues and driveability issues once running !! fuel lean/rich
Manifold Absolute Pressure (MAP) Sensor
The MAP sensor monitors intake manifold intake air volume and delivers an input signal to Engine Control Module (ECM). The ECM uses input signal for controlling fuel injection system and ignition timing (spark advance).
ALL 3 use the same ground terminal from the ECM you could check this terminal
NOTE:If Codes 22, 24, 31 and 41 are output together, inspect ECM terminal E2 (ground) circuit. Repair as needed.
let me know
Saturday, March 21st, 2009 AT 4:49 PM
