1994 toyota camry 4cyl boggs down when push on gas
STEELERBUDDY
I have a 94 camry that boggs down when you push on the gas pedal. I rechecked timing numerous times. It keeps slipping or something. It will backfire when you press on the gas as well. It is a new timing belt, wires, cap, rotor. Any other suggestions?
That problem seems to be solved, but I tried to run the car last night and it runs fine when it is cold, but then runs like a junker when it is warmed up. Unplugged the temperature sensor and it still ran like crap. More suggestions?
May 22, 2007 at 6:42 AM
  • 75,988 POSTS
[quote:2abba1725d="steelerbuddy"]I have a 94 camry that boggs down when you push on the gas pedal. I rechecked timing numerous times. It keeps slipping or something. It will backfire when you press on the gas as well. It is a new timing belt, wires, cap, rotor. Any other suggestions?[/quote:2abba1725d]
Check the throttle position and MAF sensor
May 22, 2007 at 9:45 AM
ZONER CHICK
  • 19 POSTS
[quote:f096604c9f="steelerbuddy"]I have a 94 camry that boggs down when you push on the gas pedal. I rechecked timing numerous times. It keeps slipping or something. It will backfire when you press on the gas as well. It is a new timing belt, wires, cap, rotor. Any other suggestions?[/quote:f096604c9f]
It may also be the fuel filter. The engine will bog down, kiinda gasping for fuel thru a clogged filter when you accelerate. My 90 camry manual (2VZFE V6) recommends changing it every 15k or 12 months. Wouldn't hurt if it hasn't been done recently. I would imagine it's the same time frame for yours as well.
May 22, 2007 at 11:03 AM
