1992 Toyota Camry not starting /trans
RASO
  • 1992 TOYOTA CAMRY
  • 4 CYL
  • 135,000 MILES
I recently change trans oil few weeks ago and now when I put car in drive car goes back but the light on dash does not work on drive but it works on rest gears also by coincidence car does not start any idea
Saturday, March 14th, 2009 AT 7:58 PM
JAMES W.
  • 2,394 POSTS
I'm really not sure what you're trying to tell me. Has this been a problem since the day you changed the fluid? Please advise.
Saturday, March 14th, 2009 AT 9:02 PM
RASO
No this problem just happend today and I just replaced oil for service
Saturday, March 14th, 2009 AT 9:07 PM
JAMES W.
  • 2,394 POSTS
I'm sorry, but you didn't answer my question. Did you just change the fluid today and was today when this problem started? Also, could you eplain one more time what the problem is.
Saturday, March 14th, 2009 AT 9:23 PM
RASO
Ok fluid was replaced 2 weeks ago for regular service my wife is been driving this car every day but today the car start to acting up u put in drive and car wants go back u put in reverse goes back but what is bugging me is the cluster where shows different p, n, d, 1, 2, 3, shows all except d. Also she parked car and after 3 hours I went to see whats happening and now car cranks but no start
Saturday, March 14th, 2009 AT 9:45 PM
JAMES W.
  • 2,394 POSTS
OK, now I think I understand. It sounds to me like your shift cable from the console shifter to the trans axle. I doubt if having the trans serviced would have had anything to do with it. Check the movement of the cable at the transaxle to see if it's smooth. The problem may also be in the console.
Sunday, March 15th, 2009 AT 1:50 AM
RASO
It is possible it may be trans module because the light on cluster does not light up and car cranks but no start or u think is a different issue
Sunday, March 15th, 2009 AT 2:44 AM
JAMES W.
  • 2,394 POSTS
It's not impossible. Have you checked all your fuses?
Sunday, March 15th, 2009 AT 11:33 AM
RASO
Yes all fuses ok also im cheking this car and I notice spark was not that strong and oil was deposited on plug chamber I replaced plugs wires cap rotor and now no spark, it is possible this coil that is built inside distribuitor have quit?
Sunday, March 15th, 2009 AT 1:21 PM
JAMES W.
  • 2,394 POSTS
Yes, entirely possible. Be sure you check all electrical connections at the distributor before we condemn the coil.
Sunday, March 15th, 2009 AT 2:33 PM
