1992 Toyota Camry Car will not start
ANNIEM1002
  • 1992 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,000 MILES
Just spent 2 days under the hood - thought I had this fixed, but problem persists.
Was driving and the engine shut off. Check engine light came on, pulled into a parking lot. Turned off everything from the radio to the A/C. Couldn't get it to start. Have replaced the following. ECM, distributor cap, rotor, ignition coil, fuel pump. After replacing the ignition coil, finally got it started. Started again the next morning - no issue. Tried starting it after taking the car out - won't start.
I have replaced everything I can think of - is this something to take to the dealer? Is it even worth it?
Sunday, July 11th, 2010 AT 6:36 PM
When you turn key to run do you hear the fuel pump? Answer this I need to know to figure out your problem
Sunday, July 11th, 2010 AT 6:40 PM
ANNIEM1002
The fuel pump is one of the things we replaced. :(
Monday, July 12th, 2010 AT 12:18 PM
In the airflow meter block the vane flap wide open and attempt to start-did it?
Monday, July 12th, 2010 AT 2:08 PM
