Thank you very much for your help i"ll let you know how it worked out. Coolant sensor checked out ok. Start from beginning, my problem started when we were washing off engine & car died. Now will only start when we choke off air then when the accelerator is depressed it bogs badly. Took out 2 sensors and no trouble code was alerted by the ecm. Tried another ecm. Same problem. Why can't we get the car to start by simply turning the key & why won't the ecm give a trouble code when it is obviously not running properly. Got spark and the gas pressure was tested it is good.
SPONSORED LINKS
Sunday, August 15th, 2010 AT 10:03 PM
