Most Toyota exhaust systems are bolted on a opposed to welded, so they are pretty straight foward.
Parts would be around $500. If you intend to replace convertor add $200 for direct fit unit.
If wiper motor is working, then the wiper transmission may be bad, or connection from motor to trans. Has worked loose.
SPONSORED LINKS
Sunday, February 15th, 2009 AT 7:12 AM
