1995 Toyota Avalon Steering Wheel Shake
TDINDA
I have a 95 Toyota Avalon with 107,000 miles. I have had the left axle changed. The steering rack was replaced 3 times because the first 2 were still leaking fluids. I had all four struts changed and the wheels rotated. The shaking started after the 2nd steering rack change and it has gotten worse. Whether i am driving at 10 mph or 60, it doesn't matter. If i am driving above 50 mph and i hit the brakes, the car seems to shake a lot more and the car vibrates a lot. Can you let me know what's wrong.
May 4, 2006 at 4:09 AM
LOSONE
  • 1,616 POSTS
Humm it is hard to say but back to basics tells you that when the last thing was replaced the problem occured. Go back and have it fixed with a REPLACEMENT RACK.
May 4, 2006 at 9:29 AM
Suggested Repair
Have the recently installed steering rack inspected and replaced again, since the shaking began after that rack was installed.
Conversation Summary
The owner of a 1995 Toyota Avalon reports steering-wheel shaking at all speeds that worsens when braking above 50 mph. Prior work included a left axle, four struts, wheel rotation, and three steering-rack replacements. The expert notes the shaking started after the last rack replacement and recommends having that rack replaced again.
