How necessary to replace struts?
JULIE746
I have a 1995 Toyota Avalon XLS, V6 with 175,000 miles. Sometimes when I go over bumps the rear suspension creaks or rattles (but not consistently). Car repair place said to replace struts. I'll probably sell within 6 months, so want to put off if possible. But will be need to drive on a 1000+ mile trip w/in the next 6 months. Do I need to replace for safety? The comfort of rear passengers is not relevant. Just don't want the rear of my car dragging down the interstate if they completely go. Thanks for all your help.
Nov 16, 2007 at 12:31 PM
  • 31,937 POSTS
Hi there,
If the rear suspension struts are not leaking (a wet oil stain down the strut) they should be OK, the creaking is more than likely a little movement in the mounting bushes. A quick check for strut serviceability is to bounce the rear suspension (just get the body moving up and down) let go. and the car should come to rest after 1 1/2 oscillations (about) If so they are fine for a trip.
I hope that this helps.
Mark (mhpautos) :D
Dec 5, 2007 at 1:32 PM
