Where the heck is the fluid drain for a 2000 Avalon?. 3.8L 88K I'd like to change the coolant.
thanks.
Okie
Sep 30, 2007 at 1:51 PM
SERVICE WRITER
✓Experienced Mechanic
Check the left rear of the engine block for a coolant drain union and also on the bottom of the radiator. Without having the car, I can't point it out exactly, but the petcock may look a little different than they used to be. IT may be a hex driven plug that only turns 1/4 of a revolution.
