1995 Toyota Avalon Rear Creak
JULIE746
I have a 1995 Toyota Avalon XLS, V6 with 175,000 miles. Sometimes when I go over bumps the rear suspension creaks or rattles (but not consistently). Car repair place said to replace struts. I'll probably sell within 6 months, so want to put off if possible. But will be need to drive on a 1000+ mile trip w/in the next 6 months. Do I need to replace for safety? The comfort of rear passengers is not relevant. Just don't want the rear of my car dragging down the interstate if they completely go. Thanks for all your help.
Nov 16, 2007 at 12:31 PM
  • 31,937 POSTS
Hi there,
If the rear suspension struts are not leaking (a wet oil stain down the strut) they should be OK, the creaking is more than likely a little movement in the mounting bushes. A quick check for strut serviceability is to bounce the rear suspension (just get the body moving up and down) let go. and the car should come to rest after 1 1/2 oscillations (about) If so they are fine for a trip.
I hope that this helps.
Mark (mhpautos) :D
Dec 5, 2007 at 1:32 PM
Suggested Repair
Inspect the rear struts for oil leaks and perform a bounce test. If there is no wet oil stain and the body settles after about 1.5 oscillations, the struts should be serviceable for the trip; the creak is more likely slight movement in the mounting bushes.
Conversation Summary
The owner of a 1995 Toyota Avalon with 175,000 miles reports occasional rear creaking or rattling over bumps and asks whether strut replacement is needed for safety before a long trip. The expert says non-leaking struts that settle after about 1.5 oscillations on a bounce test should be fine, and the noise is more likely from mounting bush movement.
