1996 Toyota Avalon Code 773
It is not tune up related, if it was there would be other codes. The code has to do with an electrical problem for the lock up solenoid, the solenoid itself or the computer. Probably the second of the two. If you can't find a reputable shop, contact www.snapon.com. The local rep near you can help you find a shop.
Suggested Repair
Have the code 773 lock-up solenoid fault diagnosed and repaired. Check the solenoid electrical circuit, the lock-up solenoid itself, and the PCM; the solenoid is the most likely cause. This is not a tune-up issue and should not be ignored even if the car still shifts normally.
Conversation Summary
The owner of a 1996 Toyota Avalon with 117,000 miles reported a check engine light and code 773, described as a shift-cylinder code. A transmission shop advised ignoring it because the car shifted smoothly. The expert said the PCM can override the fault so the car continues to run normally, but the problem should still be fixed. It is an electrical issue involving the lock-up solenoid circuit, the solenoid, or the computer, most likely the solenoid, and is not related to a needed tune-up.
