1998 Toyota Avalon P0135 Sensor Location Fix
TWIS14ME
I have the 1998 model and the check engine light is on the code for this is p0135 bank 1 sensor 1. please tell me where is this bank 1 sensor 1 located on the engine so that i may repair this my self?
I got this from code p0135 check engine light.
Jan 6, 2007 at 3:11 AM
  • 75,988 POSTS
You got three of those sensors.
PO135 can be a little tricky to deal with, I would replace the middle sensor on the rear exhaust. before I go farther.
Jan 6, 2007 at 4:14 PM
LOSTINMARS
  • 222 POSTS
common Toyota 3.0 v6 problem. this sensor you want to change is the one near the firewall in the exhaust manifold. make sure to find out if your car is a cal-spec or fed-spec model. the sensors are different.
Jan 10, 2007 at 9:32 AM
EREVAN
is this the one near the radiator?
Oct 16, 2007 at 2:17 PM
LOSTINMARS
  • 222 POSTS
i said "near the firewall"...so no, not near the radiator.
Oct 18, 2007 at 1:49 PM
Suggested Repair
Replace bank 1 sensor 1, identified as the sensor near the firewall in the exhaust manifold, not the one near the radiator. Confirm whether the Avalon is California-spec or federal-spec, because the sensors differ. One reply also suggested trying the middle sensor on the rear exhaust if the diagnosis remains uncertain.
Conversation Summary
The owner of a 1998 Toyota Avalon has a check-engine light with code P0135 for bank 1 sensor 1 and asks where that sensor is located. One expert says there are three sensors and suggests replacing the middle sensor on the rear exhaust. Another says this is a common Toyota 3.0 V6 issue and identifies the sensor near the firewall in the exhaust manifold, adding that California-spec and federal-spec sensors differ. When asked whether it is near the radiator, the expert says no.
