1996 Toyota Avalon Code 773
SHAE
I have a 1996 Toyota Avalon, with 117000 miles 6 cylinder. Recently my engine light has come on and I took it to a transmission specialist and code 773 (shift cylinder code) was detected. The mechanic told me not to worry about it because the car runs smoothly (no problem when changing gear no problem with car). Is the adivse of the mechanic reasonable or should I get the problem fix. (Note: the car does need a tune up could this be a possiblity why engine light is on).
Jan 23, 2007 at 9:53 AM
SERVICE WRITER
  • 9,123 POSTS
The Problem can be overridden by the pcm to keep it running normal, The problem should get fixed. IMHO The shop either is unfamiliar with diagnosing check engine lights or unfamiliar with the technology of cars.
It is not tune up related, if it was there would be other codes. The code has to do with an electrical problem for the lock up solenoid, the solenoid itself or the computer. Probably the second of the two. If you can't find a reputable shop, contact www.snapon.com. The local rep near you can help you find a shop.
Jan 23, 2007 at 9:58 AM
Suggested Repair
Have the code 773 lock-up solenoid fault diagnosed and repaired. Check the solenoid electrical circuit, the lock-up solenoid itself, and the PCM; the solenoid is the most likely cause. This is not a tune-up issue and should not be ignored even if the car still shifts normally.
Conversation Summary
The owner of a 1996 Toyota Avalon with 117,000 miles reported a check engine light and code 773, described as a shift-cylinder code. A transmission shop advised ignoring it because the car shifted smoothly. The expert said the PCM can override the fault so the car continues to run normally, but the problem should still be fixed. It is an electrical issue involving the lock-up solenoid circuit, the solenoid, or the computer, most likely the solenoid, and is not related to a needed tune-up.
