1998 Toyota Avalon Bucking
BEARCAT
I have a 1998 Toyota Avalon XLS V-6 with 137,650 miles. For some time, I have experienced an intermittent bucking problem. It is not predictable and does not cause a check engine light or other visual indication of a problem. The spark plugs have been replaced, the injectors flushed, and the ignition coils tested. These items have not solved the problem. The car has never stranded me due to the problem but it is very annoying and frustrating to not be able to find a solution to the problem. I would appreciate your advice
Sep 4, 2007 at 12:42 PM
  • 31,937 POSTS
Hi there.
I would re visit the fuel injectors, the spray pattens may be faulty and often pintals will need to be replaced to improve fuel air mixing. Injector clean in a can is just that, it will aid in the removal of lacquer build up in the fuel system, but if the spray patten is faulty due to a faulty pintal, no amount of cleaner will fix it.
Mark (mhpautos)
Sep 4, 2007 at 12:58 PM
Suggested Repair
Recheck the fuel injectors for a faulty spray pattern. A faulty pintle may need replacement; fuel-system cleaner will not correct a bad pintle.
Conversation Summary
The owner of a 1998 Toyota Avalon XLS V-6 with 137,650 miles reports intermittent bucking with no check engine light. Spark plugs, injector flushing, and ignition coil tests did not fix it. The expert recommends revisiting the injectors because a faulty pintle can ruin the spray pattern and cannot be corrected by cleaner alone.
