2000 Toyota 4Runner Rough Idle
ERFIORE
I have a 2000 toyota 4runner with 126000 miles. It idles rough. The mechanic told me to replace the oxygen sensor to the number one cylinder. Does this make sence?
Nov 17, 2007 at 11:33 AM
BLACKOP555
  • 10,386 POSTS
yes it does, but first scan it for trouble codes, that way were not just guessing various things can give it a rough idle, such as a bad IAC.
Nov 17, 2007 at 2:36 PM
Suggested Repair
Scan for trouble codes before replacing the oxygen sensor. A rough idle can also be caused by a bad idle air control (IAC) valve, so do not replace parts by guesswork.
Conversation Summary
The owner of a 2000 Toyota 4Runner with 126,000 miles reports a rough idle. A mechanic recommended replacing the oxygen sensor for cylinder one. The expert says that can make sense, but advises scanning for trouble codes first rather than guessing, noting that other faults such as a bad IAC can also cause a rough idle.
