1995 Toyota 4runner Oil Leak, Rough Idle
CONNORDION
Little over a week ago I bought a 95' 4runner, V6 3.5L, 4WD, automatic transmission with 115,000 miles on the odometer. The previous owner told me that he had the head gaskets and timing belt replaced about 20,000 miles prior and new tires..etc... I test drove it and had my father, who is somewhat of a mechanic but not enough to have me asking questions elsewhere, inspect it and figured for the price it was a good buy. I was noted by the previous owner that it had a SLIGHT oil leak which I stupidly shook off as merely a quick fix. Now it's 6 days later and i'm experiencing drastic oil leaks and a rough idle which runs about 500RPM at a stand still. I am a poor college student and don't have the extra 1-2k to fix it if it's a major problem, please help!
Oct 30, 2007 at 2:19 PM
FISHERMAN
  • 937 POSTS
[quote:6d93a5ea1e="ConnorDion"]Little over a week ago I bought a 95' 4runner, V6 3.5L, 4WD, automatic transmission with 115,000 miles on the odometer. The previous owner told me that he had the head gaskets and timing belt replaced about 20,000 miles prior and new tires..etc... I test drove it and had my father, who is somewhat of a mechanic but not enough to have me asking questions elsewhere, inspect it and figured for the price it was a good buy. I was noted by the previous owner that it had a SLIGHT oil leak which I stupidly shook off as merely a quick fix. Now it's 6 days later and i'm experiencing drastic oil leaks and a rough idle which runs about 500RPM at a stand still. I am a poor college student and don't have the extra 1-2k to fix it if it's a major problem, please help![/quote:6d93a5ea1e]
Hello !!
well start checking where the oil its leaking from, could be just a bad pan gasket.
the rough idle... inspect and clean the carbon build-up of the IAC valve and The EGR.
Question: is the MIL (check engine light) on?
let us know on your findings..
Good Luck!
Oct 30, 2007 at 3:27 PM
CONNORDION
Thanks! My check engine light is not on. I'm thinking of taking it by a local shop to have it looked at today. Hopefully nothing to major.
Oct 31, 2007 at 6:09 AM
