Rough Idle & No Power
325,000 MILES
CLEVERLION2U
3.O V-6
Truck starts right-up, but rough idle. Idle is set above 1,000 to keep running. I shift (Automatic) manually to get up to speed.
Has No power until 15 MPH, then finally kicks-in quickly as I then shift to 2nd, then to 3rd (D) & runs great up to freeway speed.
No "Check Engine" lights are on.
Thanks for your time & help,
Sincerely,
Michael Patterson
michaelpki@ymail.com
Apr 13, 2013 at 6:22 AM
first i would start with a compression test. then check plugs, wires/coil. make sure there is no vacuum leaks.
Apr 13, 2013 at 6:41 AM
CLEVERLION2U
Thank you Roy..... I neglected to mention that their is a real quick ping upon take-off only - if that would mean "Timing" perhaps ?
Thanks again,
Michael Patterson
Apr 13, 2013 at 8:03 AM
