I have a '93 4runner, 3VZ-E V6 with 4WD and 5-spd manual.
Some history:
Head gaskets were replaced 2X; the 3rd time they replaced the heads with 1997s. Ran great for years after.
I blew ANOTHER head gasket, replaced it (one side only) along with the knock sensor (they broke that off when working on the head) and also 2 fuel injectors (they said they were plugged when working on the head).
Current problem:
Recently it started running like the head gaskets were blown, extremely rough, no power, etc. Although sometimes (usually at freeway speeds) it'll suddenly start running fine... But...:
1. No steam/antifreeze in the exhaust.
2. Good compression.
3. OBD codes are 'too rich' and 'too lean'.
After these symptoms started, I failed smog and replaced the EGR valve, smog pump, pre-cat O2 sensor, and the cat converter. I also found a plugged EGR hose and fixed it, passed smog.
Same symptoms.
I replaced the knock sensor (again) since someone suggested it might be defective and it was under warranty.
I gave it a tuneup (replaced plugs/wires/cap/rotor).
So here's what's been suggested:
a. bad ignition module
b. plugged fuel injector
c. car is simply a piece of sh*t
Any ideas? I believe the rich+lean codes are the clue; but haven't been able to find anything to fix...
Some history:
Current problem:
Same symptoms.
Feb 3, 2009 at 10:06 PM
