1995 Toyota 4Runner Rich Idle
SWITCHBACK
I have a 95 4runner 3 litre 4x4 automatic with 107k. the check engine light has been on for a while. runs pretty good, mileage isn't as good as it should be and sounds a little rough when idling. had the code read and says system is rich. i checked the timing and it was a little off, was 15 degrees and should be ten at idle. i set it at ten but didn't help the idle problem. i am just wondering what i should check next, coolant sensor, oxygen sensors or maybe something else. Any advice is greatly appreciated1 Thanks.
Jun 20, 2007 at 7:19 AM
MMPRINCE3000
  • 133 POSTS
Check the TPS, O2 sensor, MAP or MAF, coolant sensor. All of which could cause a rich condition.
Check for a clogged CAT also.
Jun 21, 2007 at 9:04 PM
Suggested Repair
Check the TPS, oxygen sensor, MAP or MAF, and coolant temperature sensor, any of which can cause a rich condition. Also inspect for a clogged catalytic converter.
Conversation Summary
The owner of a 1995 Toyota 4Runner with a rich-condition code, reduced mileage, and rough idle set the timing from 15 to 10 degrees, but the idle did not improve. The expert advised checking the TPS, oxygen sensor, MAP or MAF, and coolant sensor, and also checking for a clogged catalytic converter.
