1996 Toyota 4Runner 4 runner wont stay started
KEVIN71
  • 1996 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 108,000 MILES
My 4 runner is shutting off righr after I start it I have changed the fule filter and checked the mass air flow siscer and have checked to see if the fule pump is working I an at a pluse I am not sure where to go form here It wont run to get it to a garage so I can have a computer hooked up to it so what should I do next please help
Sunday, December 28th, 2008 AT 12:07 PM
Do you hear the fuel pump come On-if not block open the airflow meter flap do you hear it now?
Sunday, December 28th, 2008 AT 12:14 PM
KEVIN71
When I changed the fuel filter we turned on the key and the fuel pump was pumping the gas out like its suppose too. So what next?
Sunday, December 28th, 2008 AT 12:35 PM
You need to check the actual fuel pressure using a fuel pressure gauge-EFI system don't like low pressure
Should read 38-44psi then comeback
Sunday, December 28th, 2008 AT 2:06 PM
