Engine
125,000 MILES
JASONWARIPALA
  • 6 POSTS
My Toyota Hilux Surf SSR-G Cranks but does not start. I installed 2 brand new batteries and a new second-hand glow plug too. It still does not start. A mechanic checked it and said there was air in the fuel so I'll bleed it. PLEASE HELP ME!
May 29, 2013 at 4:46 PM
HMAC300
  • 48,601 POSTS
check your fuel pressure, you can't getair in fuel system with an electric pump.check the pressure with a gauge
May 29, 2013 at 11:46 PM
JASONWARIPALA
  • 6 POSTS
Ok so what kind of pressure reading do I look for in the gauge?
May 30, 2013 at 2:11 PM
HMAC300
  • 48,601 POSTS
should be 38-44 psi with key on engine off but has to be activated by a scanner and you may need adapters to take it.
May 30, 2013 at 11:37 PM
JASONWARIPALA
  • 6 POSTS
thanks hmac300
May 31, 2013 at 3:48 PM
JASONWARIPALA
  • 6 POSTS
Checked the fuel lines. Fuel runs in and out of the fuel pump but there is no fuel running from the fuel pump and in the injectors. Removed the lines and pumped and there was nothing coming out. Is there something wrong with the pump?
May 31, 2013 at 7:57 PM
JASONWARIPALA
  • 6 POSTS
SORRY CORRECTION!!! Fuel runs in and out of the 'fuel filter' but there is no fuel running from the fuel pump and into the injectors. Removed the lines and pumped and there was nothing coming out. Is there something wrong with the pump?
May 31, 2013 at 7:59 PM
HMAC300
  • 48,601 POSTS
what's your pressure read above replies I gave you what you needed to check
May 31, 2013 at 10:43 PM
JASONWARIPALA
  • 6 POSTS
Pressure read is 40. Is that okay?
Jun 1, 2013 at 12:22 PM
HMAC300
  • 48,601 POSTS
as long s it was taken at the fuel rail. is this a diesel? scan for codes too
Jun 1, 2013 at 11:09 PM
