1995 Toyota 4Runner Idle and Acceleration
MATTBUNDY
My 4 runner has trouble accelerating and idleing before I reach 25 or 35 MPH. Even at that speed it seems unstable. I have replaced the spark plugs, distributor cap and wires, air filter, and tried using a fuel injector cleaner in my gas tank. Could it possibly be the fuel filter? How can I make sure before I throw any more parts at it?
Oct 30, 2007 at 9:28 AM
FISHERMAN
  • 937 POSTS
[quote:a95df1cb44="mattbundy"]My 4 runner has trouble accelerating and idleing before I reach 25 or 35 MPH. Even at that speed it seems unstable. I have replaced the spark plugs, distributor cap and wires, air filter, and tried using a fuel injector cleaner in my gas tank. Could it possibly be the fuel filter? How can I make sure before I throw any more parts at it?[/quote:a95df1cb44]
Hello!
Start checking the IAC valve and EGR (clean the carbon build-up) and also check the TPS (throtle Position Sensor)
Let us know!
Oct 30, 2007 at 3:30 PM
Suggested Repair
Inspect and clean the IAC valve and EGR valve to remove carbon buildup, and check the throttle position sensor before replacing more parts.
Conversation Summary
A 1995 Toyota 4Runner with about 112,000 miles hesitates and idles poorly below roughly 25–35 mph and still feels unstable at that speed. The owner already replaced the spark plugs, distributor cap and wires, and air filter, and used fuel injector cleaner, and asked whether the fuel filter could be next. The expert recommended checking the IAC valve, cleaning carbon from the EGR, and checking the throttle position sensor.
