1990 Toyota 4Runner not starting
JONSIPE1983
  • 1990 TOYOTA 4RUNNER
  • 6 CYL
  • 4WD
  • 185,000 MILES
The car was starting but after you turn it off it wouldnt start agan for AT LEAST AN HOUR NOW IT WONT START AT ALL.
Saturday, September 5th, 2009 AT 5:18 PM
Do below to determine if its fuel or spark related issue
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Saturday, September 5th, 2009 AT 5:27 PM
