HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
4Runner
Engine
Symptoms
Not Running
SPONSORED LINKS
1990 Toyota 4Runner DOES NOT ALWAYS START
HRLYRDR49
MEMBER
1990 TOYOTA 4RUNNER
Engine Mechanical problem
1990 Toyota 4Runner 6 cyl Automatic 206000 miles
ENGINE WILL START AND RUN FINE, BUT SOMETIMES WILL CRANK OVER BUT NOT FIRE. AFTER A DAY OR SO WILL START AND RUN FINE AGAIN.
Monday, June 8th, 2009 AT 6:27 PM
MECHANIC
Hi there,
When it wont start you will have to check for fuel pressure, spark & injector pulse, I would be suspecting fuel pump issues as a first place to look.
Mark (mhpautos)
SPONSORED LINKS
Monday, June 8th, 2009 AT 6:40 PM
HRLYRDR49
MEMBER
Will fuel pressure keep truck from firing. Checked truck for fire and was'nt any.
Monday, June 8th, 2009 AT 7:05 PM
MECHANIC
Hi there,
If you have no spark, do the scan and check for faulty cam or crank angle sensors, do this next.
Mark (mhpautos)
Monday, June 8th, 2009 AT 7:12 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1990 Toyota Corolla Wont Start
1990 Corolla 4 Door Sedan Stared Then Stalled & Will Not Start Acts Like Its Not Getting Gas The Coil Is Fine, New Cap & Plug Wires I...
Asked by
toyota02t
1990
TOYOTA 4RUNNER
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1990 Toyota 4runner Not Starting
The Car Was Starting But After You Turn It Off It Wouldnt Start Agan For At Least An Hour Now It Wont Start At All.
Asked by
jonsipe1983
1 ANSWER
1990
TOYOTA 4RUNNER
Repairs
Need Info On No Start No Spark Code 12 Toyota Camry 1990
Asked by
kathyflores
1 ANSWER
2 IMAGES
1990
TOYOTA 4RUNNER
I Have A Toyota 4runner Which Turns Over But Will Not...
I Have A Toyota 4runner Which Turns Over But Will Not Start. I Just Recently Purchased This Vehicle And Have Had No Problems With It...
Asked by
Anonymous
1990
TOYOTA 4RUNNER
1990 Toyota 4runner
1990 Toyota 4runner 6 Cyl Four Wheel Drive Automatic I Need To Know Were The Fuel Injectors Are On The Engine Because The Vehicle Will...
Asked by
JoelilGuy
1 ANSWER
1990
TOYOTA 4RUNNER
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
