Torque specs for valve cover gasket replacement needed?
2011 KIA SORENTO
151,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
AMBERBLEV
MEMBER
1 POST
I need to know the torque specs for the valve cover gasket replacement on the vehicle listed above EX model.
Jan 17, 2023 at 10:52 AM
✓Experienced Mechanic
If you look at the attached picture below, it provides the torque specifications and the tightening sequence.
When you tighten these, it is a two-step process. First, you will tighten them to approximately 3.5 ft/lbs and then a second pass to approximately 7 ft/lbs.
