throwing something out in the middle of shifting gears. What did I mess up?
1999 LINCOLN NAVIGATOR
200,000 MILES
STEPHANIE HUNTER
  • 6 POSTS
I was going from park to drive and got a little ahead of myself, before it had time to change from park to drive I hit the gas and It felt like I threw something all the way out of the bottom or rear end. I didnt allow enough time for it to get all the way into drive before hitting gas. What did I do to this vehicle. It won't go furthur that 2 ft without a terrible jolting and pulling from the bottom/rear. It drives in reverse no problem but forward it feel like I will completely destroy something. please help me figure out what I screwed up?!!
Oct 4, 2013 at 12:51 AM
HMAC300
  • 48,601 POSTS
have a local pro look at it we have no idea
Oct 4, 2013 at 1:10 AM
STEPHANIE HUNTER
  • 6 POSTS
could you just throw a few ideas, maybe the drive shaft, rear end drive axel, or universal joint?
Oct 4, 2013 at 1:30 AM
HMAC300
  • 48,601 POSTS
well if it were driveshaft/ujoint rear axle it wouldn't move either way, maybe two clutches are applying that shouldn't be in trans or a planetary gear set is messed up . that is why I always send people to a trans guy with those type of problems.
Oct 4, 2013 at 2:45 AM
STEPHANIE HUNTER
  • 6 POSTS
that sounds like a possiblity. I have little real knowledge on these things just assuming. I am so afraid of the amount of money I would have to spend with it being a Lincoln. Do you think its going to be a number $$$
Oct 4, 2013 at 4:40 AM
HMAC300
  • 48,601 POSTS
prices vary but if the trans has to be rebult you can go to most trans shops and get it done for around $1500-1800. but it may not be the trans but something not as expensive. you need to find out what it is first.
Oct 4, 2013 at 5:11 AM
STEPHANIE HUNTER
  • 6 POSTS
okay. I really appreciate you trying to help me.
Oct 4, 2013 at 5:41 AM
