I had the water pump, timing belt and seals replaced around 91, 00. I do regular oil changes, and have noticed some oil drops on floor over last year(though oil level is always fine).
Car was driving fine till yesterday. Today wife complained (after driving five miles) about burning smell and steering wheel was vibrating. Check engine lights came on.
I checked codes - P0300, P0302, P0305. I found the coolant tank was almost empty(some coolant at bottom). I found the engine compartment was sprayed with white salt type liquid and dried (I have photos).
I reset codes. Refilled coolant. I started the engine after refilling coolant it runs fine, but the steering wheel vibrates when engine is in "D". Also the panel light for "D" does not illuminate (P and R lights do illuminate).
Need help to figure out if it is a radiator issue or spark plug/coil issue. I also have some oil leaking from the engine that was already present due to age of the car.
Wednesday, July 29th, 2020 AT 5:45 PM
(Merged)
