Intermittent will not start, how to fix this?
250,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
KFRESHH2O
A couple weeks ago I drove my vehicle to the gas station a couple blocks away. When i came out of the gas station my vehicle would not start, it just kept clicking. I had a friend come jump me, i had to jump my car every time for the next day. The first thing i did was check all fuses, checked my battery, and my alternator. Once i connected my battery backup it started just fine after those 4 or 5 times. Again, i stop at the gas station, it won't start again. This time it just clicks once. I tried jumping it, nothing happened. I had several men tap on my starter for me while i tried to start it. I let it sit overnight at the gas station, came back the next morning, got under the vehicle myself while a friend turned the key. I got it to start on the first try. It started fine every time for almost 3 weeks. 4 nights ago, I drove home late, went out the next day, it won't start.
It has correct oil in it.
It has antifreeze 50/50.
It has fuel.
The battery is good.
The alternator is good.
The fuses/relays are good.
What should i look at next? Could it be a bad connection at the negative to the battery? It does have some corrosion. I can't get the negative cable back off because it is stripped way bad, any suggestions? If my starter was bad, why would it continue to start without a problem for so long? Also, it does spark at the starter when i knock on it while attempting to start the vehicle.
Jan 2, 2022 at 12:34 PM
  • 110,244 POSTS
Is the vehicle doing the same thing, a click and nothing more? As far as the negative cable, if it is corroded or loose, absolutely it can cause this to happen. Take a pic of it and upload it for me to see. Hopefully, I can give you some ideas on how to remove it. Here is a link you may find of interest:
Let me know exactly what is happening at this time. Hang in there, we'll get it figured out.
after thought... The last time you started it you indicated a helper turned the key and you were under the vehicle. Were you tapping on the starter?
Jan 2, 2022 at 12:42 PM
