1999 Ford Explorer Why my engine Won’t start after the ba
LOICO
MEMBER
1999 FORD EXPLORER
6 CYL
2WD
AUTOMATIC
127,000 MILES
Why my engine Won’t start after the battery was replaced?
Wednesday, March 4th, 2009 AT 5:27 PM
F4I_GUY
MECHANIC
I assume it doesn't crank?
Check to see if your starter S terminal is recieving power as you crank the vehicle. Also check to see if you have constant battery voltage at the starter.
Let me know what you find.
SPONSORED LINKS
Wednesday, March 4th, 2009 AT 5:33 PM
LOICO
MEMBER
1 POST
THE ENGINE CRANK BUT WONT START
Wednesday, March 4th, 2009 AT 5:43 PM
F4I_GUY
MECHANIC
Okay, then check for fuel and spark. You will most likely be missing one.
