Yes,
There will be reasonably serious consequences
But I Believe that subarus are designed so that if the cam belt breaks then it WON'T allow valves & pistons to hit each other causing a real mess.
PLEASE NOTE ON SUBARUS WHEN YOU REPLACE THE TIMING BELT IT IS IMPERATIVE YOU ALSO REPLACE THE IDLERS & TENSIONERS AS WELL AS THE WATERPUMP & THE THERMOSTAT
THE PARTS ALONE COST AROUND THE $600 NZD DOLLAR MARK AS FOR LABOUR I DON'T KNOW AS I HAD MINE CHANGED BY A MECHANIC AFTER HOURS
THANKS
SPONSORED LINKS
Monday, July 23rd, 2007 AT 2:30 PM
