1999 Subaru Forester Oil Leak
SUBARU
KRISTIJO
Recently I had my oil changed on my 1999 Subaru Forester,(55,000 miles) - at a 'reputable' dealer.
Two days later, there was a HUGE oil pool in my driveway.
Could they have possibly put on the wrong oil filter? My bill says the filter is item # PS 02870059 and the typed description of this to the right on the bill says": SL14460BP, PWFLO OIL FILTER.
I have never had a problem with my Subaru before this!
Can anyone help?
Thank you so much in advance.[/b]
Dec 7, 2006 at 12:59 PM
2CARPRO JACK
  • 11,533 POSTS
Its possible the old o-ring stayed on the engine then they rolled the new filter on over it.When that happens, as soon as you build up high oil press it will push the old o-ring out causing a leak.Or the drain plug is loose or needs a new gasket
Dec 7, 2006 at 11:31 PM
JUANROBERTS
My car had its last two oil changes at a major auto repair center. On the last oil change, they did not remove the old o-ring before putting on the new one. The engine is now seized. Do I have to take them to court, or is it expected that this company should pay for a new motor? Should I get a mechanic's opinion before towing my car to that company?
John
Dec 21, 2007 at 12:34 AM
Suggested Repair
Check whether the old oil-filter o-ring was left on the engine and the new filter installed over it. Also verify the drain plug is tight and replace its gasket if needed.
Conversation Summary
The owner of a 1999 Subaru Forester found a large oil puddle two days after a dealer oil change and asked whether the wrong filter was installed. The expert said a leftover filter o-ring can be forced out under oil pressure, or the drain plug may be loose or need a new gasket. A later commenter described a seized engine after a shop left an old o-ring in place and asked about liability, but that legal question was not answered.
