Engine Swap
SUBARU
DOJCSANY619
  • 6 POSTS
I have a 1984 subaru DL with a 1.8L engine the axles have been giving me trouble for the last few years and im tired of replacing them. I found a 1992 subaru Legacy that has a bad Engine and I would like to know if the engine mounts and the transmission in the 1992 legacy would match so I could swap my engine to the legacy?
Thanks in advance for your help :)
Jan 29, 2007 at 2:16 PM
BRENDONR
  • 22 POSTS
I doubt it'll be that simple to simply dump your motor/tranny into the Legacy
Your '84 has a 1.8L motor, while the '92 Legacy has a 2.2L. Not sure about the transmission differences though...
Perhaps somebody else can help a bit more than I...
Jan 30, 2007 at 1:44 AM
DOJCSANY619
  • 6 POSTS
I made a rather large mistake in my original post the car I want to swap my engine into is a 1992 subaru loyale, and I would like to keep the transmission in the loyale and just put in my engine. The only major difference I am aware of is that my engine is carburated and the loyal is fuel injected. I was wondering if my engine would mount to that transmission and if it had the same engine mounts on the frame? srry about the mix up I hope this makes more sense.
thx again
Jan 30, 2007 at 5:34 AM
BRENDONR
  • 22 POSTS
Ahh.... well this fact complicates things a little.
I've got a 93 Legacy - and truely have NO idea what teh Loyale has for motor/tranny.
The simple fact that you're trying to take the motor out of your '84 DL into a '92 Loyale makes me skeptical it'll simply 'match up'.
8 years difference... I'd be REALLY carefull to see if it'll work the way you want. Sorry I can't really be more help.
Feb 1, 2007 at 1:00 AM
MIKE H R
  • 3,094 POSTS
The engine should fit in. to be on the safe side get in touch with a junk yard. they can tell you right away if it would fit using engine swap manual.
Feb 4, 2007 at 12:53 AM
