1995 Subaru Legacy Timing Belt Risk
SUBARU
TONYSTPETERS
I have a 95 Subaru Legacy Outback. According to a website I was reading, non-interferance design engines can withstand a timing belt break without damage to the engine. If my engine is a 2.2 SOHC engine then it would qualify as a non-interferance type of engine, correct?
Therefore, my questions are:
1) Is this correct that my 95 Subaru Legacy/Outback wagon is a 2.2 SOHC engine (it has the original engine in it)?
2) Does an SOHC engine constitute as a non-interferance type engine?
3) If my belt breaks because of extended use and there is no engine damage would it simply require a new timing belt or additional work? If so what kind of costs would I be looking at?
Mar 20, 2007 at 11:15 AM
SERVICE WRITER
  • 9,123 POSTS
1- yes it is.
https://www.2carpros.com/diagrams
2-SOHC stands for single over head cam
whereas
dohc is dual over head cam.
There is no bearing on whether it is interference or not due to the sohc or dohc.
3-I wouldn't expect more costs necessarily, but I would be concerned with it happening at a bad time.
AKA on the thruway, on the way home from happy hour, rushing your loved one into the hospital etc.,
There is the inconvenience, the tow bill, the diagnosis bill (hopefully there are accurate) and maybe at the expense of where you are and that shops schedule.
Mar 20, 2007 at 12:30 PM
SCUBARU
  • 71 POSTS
In 1995 Subaru went from roller hydrolic valvetrain to mechanicaly lash adjusted .Most people including techs from Subaru Get this wrong all the time .But If you have a 2.2l l from mid year 1995 to 1998 it is A interference engine .Do not find this out the hard way.I have seen more than i can count bend valves.Because there wasnt a engine size change when Subaru Changed the legacy platform in 1995 most pulications incorrectly report this as a non interference engine like the 90 to 94 2.2l were.But if you have ever done a t belt on one you will see that its possible to have the valves make contact with the piston.when turning the cam seperate from the crank shaft
Mar 21, 2007 at 11:48 AM
SERVICE WRITER
  • 9,123 POSTS
good info, Scubaru, I would haven't known!
Mar 21, 2007 at 11:53 AM
Suggested Repair
Treat a mid-1995 through 1998 Subaru 2.2L as an interference engine, not a non-interference engine. Replace the timing belt before it fails. If the belt breaks, expect possible valve-to-piston contact and bent valves, so diagnosis and repair may involve more than installing a new belt.
Conversation Summary
The owner of a 1995 Subaru Legacy Outback asked whether the original 2.2 SOHC engine is non-interference and whether a broken timing belt would only need belt replacement. An expert confirmed the 2.2 SOHC identification but said SOHC versus DOHC does not determine interference design, and noted mainly the inconvenience and related costs of a roadside failure. Another contributor corrected that mid-1995 to 1998 2.2L engines use a mechanically adjusted valvetrain and are interference engines, unlike 1990-1994 2.2L engines, and reported bent valves after belt failure. The expert accepted that correction.
