I installed a timing belt on a 1999 Subaru Legacy Outback. I lined up all the marks on the timing belt according to the gears, all lined up perfect. Then I turned the motor over by the crank and the marks disappeared on the timing belt but the gears still line up. Even after turning the motor over several times I still can't get the marks and the gears to line back up. Should I worry or is this normal?
Thank you for your time
SPONSORED LINKS
Sunday, March 12th, 2006 AT 12:15 AM
