1997 Subaru Outback O2 Sensor Location
SUBARU
TBENNER307
1997 Subaru Outback 192,000.
Had a diagnostic run for check engine light warning. Was told O2 sensor bad. How many sensors are there and where are they located? Thanks.
May 26, 2006 at 10:25 AM
LOSONE
  • 1,616 POSTS
A 97 probably only has one and it is in the exhaust manifold near the engine. If it has two the second one is behind the catalytic converter. Go to a parts house and see how many they list. It is different with Cal. specs or normal specs.
May 26, 2006 at 10:58 AM
Suggested Repair
Confirm the O2 sensor count with a parts listing for California versus federal emissions specs. A 1997 Outback likely has one sensor in the exhaust manifold near the engine; if a second is fitted, it is behind the catalytic converter.
Conversation Summary
The owner of a 1997 Subaru Outback with 192,000 miles was told an O2 sensor was bad after a check-engine diagnostic and asked how many sensors there are and where they are located. The expert said a 1997 likely has one sensor in the exhaust manifold near the engine, and if it has two the second is behind the catalytic converter. The count can differ between California and federal specs, so it should be confirmed with a parts listing.
