1991 Subaru XT6 No Blower Fan
SUBARU
CASDB25
1991 subaru xt6 65000 miles i have no fan when i use a/c or heat or anything no power at blower motor i have a new blower relay i wanted to know if thats problem and if it is where is this relay located at thanks
Aug 12, 2007 at 5:45 AM
  • 75,988 POSTS
[quote:9e8c2a48f8="casdb25"]1991 subaru xt6 65000 miles i have no fan when i use a/c or heat or anything no power at blower motor i have a new blower relay i wanted to know if thats problem and if it is where is this relay located at thanks[/quote:9e8c2a48f8]
Its on the botttom of the dash center console next to the ignition relay L/side the other side is the F/pump relay.
Hope this helps
Aug 12, 2007 at 10:31 AM
Suggested Repair
Locate the blower relay on the bottom of the dash center console next to the ignition relay on the left side; the fuel pump relay is on the other side. Confirm the relay and power supply to the blower motor.
Conversation Summary
The owner of a 1991 Subaru XT6 reports no blower fan for A/C or heat and no power at the blower motor, and asks if a new blower relay is the problem and where it is located. The expert says the relay is on the bottom of the dash center console next to the ignition relay on the left side, with the fuel pump relay on the other side.
