1997 Chevy Silverado Blower Fan Dead
ESPAEN
I have a 1997 Chevy Silverado K1500 4X4 mileage: 120,000 V8 5.7L
I have only had it for 6 months and the fan has not worked on high since I have owned it. And the other day it quit working on all the speed settings. All the fuses check out. I just replaced the resistor and that didn't help. I also straight wired the blower motor to the battery and it works just fine. I'm guessing it might be the switch or maybe the relay.
Any possible suggestions? Thanks in advance for your help.
I just replaced the switch and everything works fine now, that's all it was.
Jul 12, 2007 at 7:21 AM
DENNYP
  • 1,824 POSTS
[quote:a0d5aedd38="espaen"]I have a 1997 Chevy Silverado K1500 4X4 mileage: 120,000 V8 5.7L
I just replaced the switch and everything works fine now, that's all it was.[/quote:a0d5aedd38]probably the blower control switch. they are common failed part
Sep 29, 2007 at 9:37 AM
Suggested Repair
Replace the blower control switch. The owner confirmed that a new switch restored all fan speeds after the fuses, resistor, and blower motor had already been ruled out.
Conversation Summary
A 1997 Chevrolet Silverado K1500 had no high-speed blower operation, then lost all fan speeds. Fuses tested good, a new resistor did not help, and the blower motor ran when wired directly to the battery. The owner replaced the blower control switch and all speeds worked again. The expert agreed that the blower control switch is a common failure.
