Stopped for gas then truck would not start
195,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
WKAYSER
Truck normally starts right off. I had half a tank of gas, stopped and filled up truck cranked but wouldn't run, left truck at gas station came back next morning truck cranked right up drive to hotel. Truck started right up, went to a store truck won't start again. Cranks over but won't start. Sprayed carb cleaner truck runs until cleaner fuel is burned then dies. Waited hour or so, added heat to fuel tank. Attempted to start several times won't run. Tried one last time truck starts I drive home hour half ride. Get home turn truck off starts right back up. Next morning truck runs fine. Thought maybe the relay is going out but it has never died while running have not been able to locate where relay is at.
Apr 22, 2019 at 11:45 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It seems you might be having a fuel pump issue. First thing you should do is perform a fuel pressure test to see if you might be having a weak/failing pump.If you don't have access to a pressure test most auto parts stores have a tool loaner program and will loan you one. Here is a tutorial showing what is involved:
The specifications show the pressure should be 33-37 PSI at idle. Hope this helps and thanks for using 2CarPros.
Danny-
Apr 23, 2019 at 4:23 AM
