We need to start with figuring out what is causing the no start. You need fuel, spark, and compression in order to start the engine. So let's start with using starting fluid in the intake and see if the engine fires. If it does then we will tackle a fuel issue.
Next pull a plug out and hold it against the block and crank the engine to see if there is spark. If not, we can tackle a spark issue.
The only catch is if we have a no spark issue we could still have a no fuel issue so we need to go step by step.
Here are some guides that will help with this:
https://youtu.be/dCjmRL3p4Cs
Sep 20, 2020 at 12:19 AM
