Intermittent starting issue?
104,000 MILES • 0.5L • 6 CYL • AUTOMATIC
PATTY WOODS
Starts sporadically. No rhyme or reason. Replaced fuel pump and filter, gas lines, modulator. Run good once it starts. Turns over but just won't start, other times starts no problem. Any suggestions would be appreciated. Had it to 3 garages already.
Dec 5, 2023 at 3:57 AM
  • 110,248 POSTS
Hi Patty,
We need to narrow down the possibilities. Here is what I need you to do:
When it won't start, see if it will start if you use starting fluid. If it does and then stalls or continues to run, we know it is fuel related. If there is no change with the starting fluid, then I need you to check if there is spark to the spark plugs.
Here is a link that explains how to do that:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know what you find. Also, let me know if the check engine light stays on when the engine is running.
Dec 5, 2023 at 10:27 AM
PATTY WOODS
Have not tried interventions. The truck has been starting but I don't know for how long. Will try your suggestions when it won't start again and let you know. Thank you for your help.
Dec 7, 2023 at 6:57 AM
  • 110,248 POSTS
Sounds like a plan. Let me know if things change or if I can help in any way.
Dec 7, 2023 at 12:27 PM
PATTY WOODS
I traded the truck in today, tired of the hassle.! Thank you for all your help!
Dec 8, 2023 at 6:29 AM
  • 110,248 POSTS
Thanks for the update. That is certainly one way to resolve the issue. LOL
Take care of yourself and feel free to come back anytime in the future.
Dec 8, 2023 at 1:52 PM
