If though, the fuse still blows with the starter relay removed you could also eliminate the starter, solenoid and the wire to it as the problem, then you would have to switch your focus to what the ignition switch feeds when the ignition key is only in the start position, such as the transmission control module on one wire from the ignition switch and also a fuse #17 in the junction block which feeds several items, so to eliminate that as the problem or anything after fuse #17 is to remove it while recreating the fuse #8 blowing by turning the key to start when running the garden hose over everything and/or allowing the car is be cold. You may not be able to recreate the fuse #8 blowing. With that done said, you would either have to wait until the problem comes back and know what relays or fuses to remove in order to test or just be well prepared on what to try, which is probably not the best approach but you may be limited to that approach, so they would be the trying a new starter relay. And things along that line.
SPONSORED LINKS
helpful?Yes
Monday, August 3rd, 2020 AT 1:41 PM
(Merged)
