starter grind on flywheel?
214,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
REDBONE
  • 105 POSTS
I replaced the old starter with a new one and when i started it the starter sounded like it isn't releasing the fly wheel fast enough. After it starts i don't hear the grinding noise. What could cause it, because it didn't do that with old starter.
Feb 16, 2024 at 4:56 AM
  • 110,251 POSTS
If possible, could you record what it is doing and upload it for me to hear?
Also, it could be a few things. First, it could be a faulty new starter motor. Also, it may not be fully seated and straight. Confirm that isn't an issue. Also, it wouldn't be common, but it may require a shim to pull it a bit from the flywheel.
Keep in mind, a sticking relay can keep the starter engaged.
Let me know if you have already checked these things.
Feb 16, 2024 at 10:56 AM
