Engine Mechanical problem
1996 Ford F150 V8 Four Wheel Drive Automatic
sounds like alot meatel grinding on start up but can move switch back very little and noise goes away
Saturday, February 14th, 2009 AT 7:09 PM
BLUELIGHTNIN6
MECHANIC
Sounds like your starter is staying engaged. Usually caused by a faulty starter solenoid or faulty ignition switch. Since you state that it goes away by moving switch I would suspect faulty switch.
