You need to test for spark, fuel pressure and injection pulse, make sure that the engine has not seized after the over heat problem. Can you turn the engine by hand? If so check that the starter is okay, the click sounds as if the starter solenoid is engaging and the starter is not turning.
SPONSORED LINKS
Monday, October 16th, 2017 AT 4:35 AM
