You mentioned that you were getting a live data scanner. Do me a favor, check the coolant temperature sensor reading, let me know the short term fuel trims, and if you haven't, (and I think you did) reconfirm there are no vacuum leaks.
I am starting to question if there is a problem with the idle air control valve. Most can be serviced, but this one can't.
The info from the live data scanner may be very helpful. We spoke about it a few posts back but then stopped.
Tuesday, December 15th, 2020 AT 12:21 PM
(Merged)
