1999 Dodge Ram No Acceleration
CPERRIN
My husband has a 1999 Dodge Ram 1500 with just over 190,000 miles. He is currently travelling on business in Kingman, AZ where he is broken down. He said that the truck will not accelerate past about 30 miles per hour and it is also running very rough. Based on other questions answered in this forum, I am guessing that the problem is the fuel pump and possibly the fuel filter. Do you agree with this guess and are both located in the fuel tank?
Sep 12, 2006 at 6:31 AM
DIGUGLIELMO
  • 28 POSTS
i do agree with the problem. But the fuel pump is inside the tank and filter is along the driver side on the frame rail. i would just do the filter first. the pump is a good 2 day job if done right.
Sep 25, 2006 at 7:29 PM
BUBBA_KOSKI
  • 129 POSTS
the fuel pump and filter will ease the idle but not fix the acceleration problem, have the compter checked out along with a compression test
Sep 27, 2006 at 3:59 PM
Suggested Repair
Scan the computer and perform a compression test. Replacing the fuel filter or in-tank fuel pump may ease a rough idle but, per the expert, will not fix the acceleration problem.
Conversation Summary
A 1999 Dodge Ram 1500 with over 190,000 miles will not accelerate past about 30 mph and runs rough. The owner suspected the fuel pump and filter. A reply agreed and noted the pump is in the tank while the filter is on the driver-side frame rail, suggesting the filter first. The expert said the pump and filter may ease the idle but will not fix the acceleration issue, and recommended checking the computer and doing a compression test.
