2001 Dodge Ram Fan Wobble After Belt Failure
PMCD1983
I have a 2001 Dodge Ram 1500 with 117000 miles. It has a 5.2L V8 and I haven't really had any problems. The belt has been replaced once or twice, I just can't remember. On a recent long distance trip, I spent the entire time driving in the rain. The belt starting squealing so I stopped to check to make sure everything was ok. Everything was fine. I returned home and upon turning on my street a clanging noise started coming from the engine compartment. When I pulled into the driveway, part of my belt had come off and was wrapped around the fan. I got the pieces of the belt off the fan and replaced the belt. Now, when I turn on the truck, a weird sound starts and the fan seems to have excess wobble. Is this easily fixable? Should I continue to drive the truck or should I have it towed to a repair place to have it fixed?
Jul 21, 2007 at 12:07 PM
2CARPRO JACK
  • 11,533 POSTS
Usually if the belt comes apart in strips it is due to misalignment.Look carefully atthe front of the engine for any accessory that is at an angle or not aligned with the rest of them.Might even want to remove the belt and spin all accessories by hand to check for play.The fan requires a special set of wrenches to hold the w/pump pulley while loosening the fan
Jul 22, 2007 at 12:29 AM
PMCD1983
I checked all the accessories and the only one with excessive play is the actual fan itself, as far as I can tell. It looks as though there are two screws that may be loose on it.
Jul 22, 2007 at 5:33 AM
2CARPRO JACK
  • 11,533 POSTS
did tightening them make the play go away?
Jul 23, 2007 at 12:25 AM
PMCD1983
Unfortunately, it did not. I took the truck to a repair shop that I use and they told me that the water pump had a bearing that had gone bad over time. The water pump that is in there is the original water pump. Does this sound like a logical explaination?
Jul 23, 2007 at 10:08 PM
2CARPRO JACK
  • 11,533 POSTS
Sure does. The new cars and truck with automatic tensioners keep alot of tension on the belt, so when an accessory bearing starts to go out, it really will make noise and wobble
Jul 24, 2007 at 1:02 AM
Suggested Repair
Replace the original water pump, whose failed bearing is causing fan wobble and belt noise. Also check accessory alignment and spin the accessories by hand for play before installing a new belt.
Conversation Summary
A 2001 Dodge Ram 1500 developed belt squeal in the rain, then a clanging noise as the belt came apart and wrapped around the fan. After a new belt was installed, the fan still wobbled and made noise. Accessory checks showed play only at the fan, and tightening visible screws did not help. A shop found a failed bearing in the original water pump, which the expert agreed is a logical cause because high belt tension makes a failing accessory bearing noisy and wobbly.
