2001 Dodge Ram Rough Idle
JROB1965
I have a 2001 dodge ram 1500 4w4 sport 5.9 360 and the problem I am having is that it is running rough with no codes, replaced spark plugs ,wires, cap and rotor ,coil, iac a timesnd still the same. It does it at all times,cold or hot,also advanced timing 0n#1cylinder is jumping around at idle while on my obd2 tool.you can feel it shaking inside truck,very strange with no codes :?:
Apr 15, 2006 at 6:54 AM
LOSONE
  • 1,616 POSTS
Miles on the truck?? Do a dry and wet compression test. It sounds like you may have a valve issue. You should also do check for vacuum leaks. Find a mechanic that has a smoke machine. It is the best way to islolate a vacuum leak. Good luck
Apr 15, 2006 at 12:27 PM
Suggested Repair
Perform dry and wet compression tests to check for a possible valve problem, and inspect for vacuum leaks, preferably with a smoke machine.
Conversation Summary
A 2001 Dodge Ram 1500 with a 5.9 runs rough at all temperatures with no codes and noticeable shaking. Plugs, wires, cap, rotor, coil, and IAC were already replaced, and cylinder 1 timing jumps at idle. The expert asked about mileage and recommended dry and wet compression tests, a vacuum-leak check, and a smoke test.
