Speedometer, odometer do not work?
LCN79
  • 1991 FORD F-150
I just replaced speed sensor not more than ten minutes ago and the cable is fine too I checked but the speedometer isn't working cause it affects the way the truck shifts (stupid design) is there anything else what can cause it not too work. Also my gauge is fine cause while cable was mounted too sensor I spun the little wheel and I saw the needle jump on gauge
Tuesday, April 6th, 2021 AT 6:13 PM (Merged)
WRICE33
I have a 93 Ford and had the same problem. Believe it or not all it is is a burned out fuse. I think it was #8 in the fuse box but can't remember that for sure, it was about a year ago it happened. It makes the shift from 1st to 2nd very rough and the speedometer doesn't work at all. Replace the fuse and it runs like new and the speedometer works again. Hope this helps.
I just replaced speed sensor not more than ten minutes ago and the cable is fine too I checked but the speedometer isn't working cause it affects the way the truck shifts (stupid design) is there anything else what can cause it not too work. Also my gauge is fine cause while cable was mounted too sensor I spun the little wheel and I saw the needle jump on gauge[/quote]
COWBOY4768
  • 1989 FORD F-150
  • 6 CYL
  • MANUAL
  • 250,000 MILES
I am trying to fix up my F150 and would like to know if a the instument cluster can have have a speedometer cable and an electronics plug connected to it at one time; if so how? Thanks for your help in advance.
Gerald
INDYUKE
  • 416 POSTS
Yes it can. Were you the one with the inoperable speedometer? I've found the best way to check the speedometer is to undo the bolt that holds it to the tranny, pull it out and give it a whirl with your fingers while having someone watch the instrument speedometer gauge. If it doesn't move than you know either the cable is bad/broken, it's not connected very well to the instrument cluster or the (rare) speedo gauge isn't functioning like it should.
If this isn't your problem, just reply and let me know. I thought there was someone here who posted a problem like this, but I didn't get a chance to reply and I forgot who it was.
LORRIEHAVNFUN
  • 1977 FORD F-150
  • 120,000 MILES
I have a Ford F-150 and my speedometer is not working. I know it's not electrical, but I don't know how to pull out the speedometer to figure out what is wrong with it. Please help me. I don't really have the money to pay someone to fix it. Thank you.
Tuesday, April 6th, 2021 AT 6:14 PM (Merged)
CARADIODOC
  • 33,916 POSTS
The speedometer head is the last thing to suspect. The exception would be if the odometer still works.
First suspect the cable. They can snap or the square end at the transmission can round off inside the gear. You may be able to reach behind the instrument cluster to disconnect the cable, then watch or feel if it turns when you move the truck. It's often easier to disconnect the cable at the transmission, then spin it with your fingers while a helper watches the speedometer. That's also the time to inspect the end to see if it's rounded off.
The gear inside the transmission could be stripped too but that's not as common as a snapped cable. If the odometer does work, that would prove the cable and gears are okay. Usually when the speedometer head fails it gives a lot of warning first. The needle will typically bounce around a lot and the assembly will make noise. On rare occasions the head can lock up and cause the cable to snap, so if you find the cable is badly twisted, check the replacement for free movement with your fingers. A locked-up factory cruise control servo can do that too. They were run by the speedometer cable.
LORRIEHAVNFUN
I understand this part. But how do I get to the speedometer cable to fix it. My problem is I am not sure how to get to the cable to check it. If you could please send me that information I would appreciate it.
CARADIODOC
  • 33,916 POSTS
If you're not familiar with what a speedometer cable looks like your best bet is to get a copy of the manufacturer's service manual. There will be line drawings and a description of how to remove the end from the transmission. You might find it on one of the online service manual companies too. My computer won't let me access them. I've never figured out why and I gave up trying a long time ago.
All of the speedometer cables in the '70s and '80s were pretty basic. Most had a metal cap that screwed onto the transmission. Typically you will need a pair of pliers to loosen it, then you just unscrew it and pull the cable off. You'll see the spiral-wound cable inside the casing. Spin that cable with your fingers while a helper watches the speedometer. If the needle flickers, the cable is okay.
